I agree. Love my kiwi. Iget both better speed under power and better light air sailing. Not a stock holder either, but I would also be tempted.My First 38 has a Kiwi, and I think highly of it, and found the company fantastically helpful when the yard broke the thing. Several advantages it offers besides the lower price is the ability to tune the pitch with a hex wrench and the fact it's pitch is way higher in reverse, giving it really good maneuverability. Not a stockholder, but I'd be tempted!
It is important to know what your engine/transmission manufacturer recommends. Yanmar has a directive to sail with the transmission in neutral. If you do that you won't see much in the way of a speed increase under sail, but as Doug notes you will have to listen to that shaft rotate. A feathering prop like my MaxProp provides substantial reverse thrust, little walk, and excellent light air sailing. A full-batten main helps too.I am the owner of a bene 40cc. She is a good sailer in a breeze but a bit of a slug in light air. has anyone out there tried a folding prop on the oceanis 40 hull ? would be interrested to know if light air performance was improved.![]()
Not all transmissions mated to a Yanmar require neutral. You have to know the type, and the relevant directive. There are feathering props, and folding props, lots of variants.Thanks for all he input. will likely go with a folder of some sort. BTW, I have been sailing a yanmar powered boat since 1986 with the trans in reverse while sailing, no adverse effects .
