which one?
Hello Nigal,Thank you for your note. Whether you switch to a feathering or a folding propeller the impact to your forward motoring efficiency should not change all that much. You may see some differences in maintaining forward speed when confronted with heavy winds or sea with the folder but all in all not much change. The major differences between the two styles of props start at your reverse. Reverse for a folder can range from no change to a substantial loss of control. A feathering propellers reverse efficiencies often duplicate its forward efficiencies but this increase can, however, result in no change or could even enhance the walking problem you may currently experience. Sailing speeds with both units will be apx. the same. Costs for either a folding or feathering two blade configurations can range from $300 to $1,400 depending on the brand. Most folding propellers come in a two-blade configuration, Gori I believe now has a three blade folder, where most feathering propellers company’s have both two and three blade units. Most three blade units run from apx. $1,900 to $2,100. The only time a three blade is not a better choice over a two blade is when the two pounds of drag difference is a priority. A three blade will help keep the running gear quite and smooth. In most cases a three blade is as much as 30% more efficient. This helps to maintain the speed of the vessel when it is confronted with heavy winds or seas. My own personal choice of a propeller is a three blade feathering. Hope this helps you. Sincerely Kevin.
