You are 'mostly' right. Yes, computer aided sail design 'can' lessen the use of foam luffs by the somewhat complex shape of the leading edge (entry) shape of a luff; but, this also assumes that the tension in the forestay is absolutely correct to match the calculated curves (complex luff hollow geometry) in the front edge of the sail ... something that almost all cruisers and a lot of racers simply dont do. In most cases the computer cut quasi-curve will be 'sufficient' for a so-so roll/reef ... but not always and especially true for 'big' rigs with very long luff dimensions that are difficult to predict the forestay 'sag' accurately. In these circumstances a smaller foam luff is usually needed to compensate for what the complex computer cutting cannot do nor predict.Seriously, I was under the impression that the foam luff in jibs were a thing of the past replaced by computer technology in sail cutting. Will someone please correct me if i'm wrong
My impression is that a good furler/reefer such as a Harken MKIV is independently swiveled at the head and the tack, making a foam luff unnecessary. I would much prefer to invest my money in a premium furler and avoid the performance sapping foam luff.
