Per the Manual...
Popeye, Per the manual the foam blocks will keep the 25 afloat even if fully swamped. If i recall they show a picture of a 25 with a hole in the hull that is still afloat because of the blocks. It would definately not make for a pleasant day but if would keep you alive and relatively safe until help arrives or you make it to shore. I would think you may even be able to make headway under sail even in this condition. I believe that my 25 has all of its original foam blocks in place. I know the area under the v-berth is full and I had to remove the ones under the starboard quarter to replace some hardware a couple of years ago. After retrieving my son from what he considered the "cave of doom" I replaced the blocks. My opinion of them, they don't really add enough weight to the boat to make much difference; yes, they do take up space that could be used for storage; yes, they can be a pain to remove when you have to get in there, but, for the peace of mind of knowing I can't sink I think I will leave them alone. I had thought about removing some to put a set of drawers under the setee or v-berth but have decided to leave well enough alone. A rubbermaid bin under the cockpit can store what I need. (Hey, that would float also in a pinch!). As to Fred and his conservative sailing. That would describe me as well and I never planned on rolling her onto her beam. Additionally, I sail on the Chesapeake where there is a real chance of some drunk idiot on a powerboat ramming you. They like to swerve as close as they can to cause a wake before turning away with no regard to safety or right of way. If your boat gets holed without foam it is going down. With it it may live for another day. Plus, with thru-hull fittings, floatsam, etc, any boat can take on water. Nope, the foam stays. If I ever sell the next owner can remove it. I won't. Just my opinion. -John
