FM radio interference
42
Beneteau 361 Stockton, MO
My battery charger causes interfence with FM radio reception. The strongest local channel will come in OK, but somewhat weaker channels won't. Any suggestions?
Jack
just for starters..
The first thing I would do is try a battery operated inside your boat. If you get the same noise the on the portable radio than filters on the wires won't work. If you don't get the noise on the portable radio than a better ground or filters may help. good luck, Jack
Aug 3, 2005
181
Morgan 33 O/I Green Cove Springs FL
What type of battery charger
is on your boat? Is it an electronic three stage? Is it a ferroresonate type. The kind with a transformer. Fair Winds Cap'n Dave
John
Bad FM radio
My radio would not play clear when chargeing four 6 years. I found that my ALT ground was not hooked to anty thing and when chargeing the Fm was not clear both alt ang heart charger where hooked to a battery pin out of site.The moter and inverter /charger was grounded thru the starter ground,thru the motor plug with origanal wireing .one day my plug just melted off and that sent me looking for a problem. John
