fluxgate location
17
Hunter 34 Milwaukee
Where is the most common place to install a fluxgate compass for autopilot on a Hunter 34 ?
Thx
Sep 4, 2007
795
Hunter 33.5 Elbow, Saskatchwen, Can.
Mine's in the cabinet beside/under the nav station. Towards the rear at the divider between the aft. berth and nav station
Jul 25, 2007
320
-Irwin -Citation 40 Wilmington, NC
You want it low and close to the vessel center. Also away from stowed equipment and anything magnetic
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
I installed mine on the small cross partition at the rear of that small awkward to reach little space where the stuffing box and shaft log is located. I put it fairly near to center and just under the floor of the aft berth.
Nov 6, 2006
10,243
Mine close to where Richard's is, under the aft bunk in the little cubby outboard of the strut mounts. Far away from the iron keel and the engine block .. just be careful with things on the bunk. The flange is facing outboard. On my old Raymarine 4000+, the autopilot had a really tough time driving until I installed a rudder position sensor.
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
I have only installed a flux gate compass on a Catalina 28, and the auto-pilot I use has an internal compass.
If I recall correctly, the installation is supposed to be centered and away from magnetic interference (i.e. the engine and keel). This eliminates the low and aft areas from consideration for ideal operation. I am surprised at the installation suggestions offered, but I guess they work. I would mount the flux gate inside the head door on the bulkhead, since Hunter uses a wood compression and I have an aluminum one, neither having magnetic effects. This area is centered and about the waterline depth. On the Catalina the flux gate was installed on the forward berth bulkhead.
Mark48
Mar 1, 2008
166
Hunter 34 Milwaukee
Just remember to keep your tool box stored away from the compass. I was keeping mine in the stern berth and for a while wondered why my steering compas read about 15 degress off my helm compass. Little things to remember!
PGIJon
Mar 3, 2012
856
Hunter 34 Punta Gorda
Mine in the same location as Dan's and it works great there! A thought just popped in my head... If need a hip replacement and I sleep in the aft bunk will the autopilot fail????? Hmmmmmm
