320 Install
On my 320, I installed the Fluxgate below the galley/sink cupboard amidships into the liner. It worked well, and kept it away from metal that could interfer with it's operation. Just remember not to put any steel cookware on the bottom shelf!The install went well, with the biggest pain getting the wiring up to the stearing console. You won't need to mount the pin for the drive, as the motor hole in the pedistal will work fine for keeping it from rotating. As a matter of fact, I did mount my pin and later removed it because it caused binding as the drive turned.Good luck.Steve
