Fluttering RF main sails.
Doug
Like a lot of Hunter owners with roller furling main sails I have a lot of leach flutter. The most common fix is to to ease the out hual creating a lot of draft ( 2-3' on my hunter-36 ). This delets the option of flattening the sail as the wind increases. Do we forget this option and just furl the main. Can this be corrected by re-cutting the sail or by other tunning options. Using the leach line puts a awfull curl in the sail befor stopping the flutter. Is this the product of a batten-less sail and sheeting to a arch?
Bill Colombo
RF Mainsail Leeches
Doug, RF mainsails are great in terms of convenience but not in terms of performance or longevity. Most look pretty good out of the box but rather quickly develop a draft aft profile with a pronounced hook at the leech. This is caused by the fact that the furler puts extra strain on the leech when it is furled or reefed. Also there are no battens to keep the leech straight. Unfortunately there is not a whole lot that can be done about this since you can't change the cause of the effect. You can take the sail to the loft once a year and have your sailmaker put some take-ups in the leech. This should improve the situation temporarily. I do think you are better off living with the hooked leech rather than sailing with the outhaul drastically eased off. Next time you replace the sail look into getting a sail with a bit of positive roach supported by vertically oriented battens. We have built quite a few of these sails and they have gotten rave reviews from owners who say that the new sail dramatically improved their boat's performance. Thanks, Bill C. Doyle Sails
Jack w
What would you estimate
Estimate of cost for this new sail for a 2005 Hunter 36?
