Doug
Peggy:Our home lake is fresh water and, like most freshwater lakes, prone to alge growth throughout the summer. Sometime back, I was advised to not introduce lake water into our flushing process and instead to use a couple of cupfuls from our freshwater tank to rinse and flush the bowl. The logic was that the lake water contained these various algae which would find fertile breeding conditions in our holding tank and could produce a nasty contamination problem. I am beginning to question this logic since we use a chemical tank treatment each time we pump out. Therefore, I am considering reattaching the pump to the thru-hull and enjoying the convenience of simply flipping the pump lever to rinse the bowl. Do you have any advice or comment regarding this matter?
