Flushing through the Freshwater Tank
Mar 21, 2015
28
A general question please, what can people recommend for flushing through the freshwater tank? There seems to be a few theories on best chemicals/ treatments on the internet. CheersJeremy
Feb 1, 2001
15
“Add 1 teaspoon of any 5.25 percent solution of sodium hypochlorite—such as Clorox, Purex, Sani-Chlor, Hy-pro or Super-X—to every 5 gallons of freshwater. Let it sit with the cap off your tank for at least 30 minutes so that the chlorine has a chance to work and the fumes dissipate.”
Excerpt From: Lin Pardey & Larry Pardey. “The Care and Feeding of Sailing Crew.” L and L Pardey Books. iBooks.
This material may be protected by copyright.
Check out this book on the iBooks Store: ‎The Care and Feeding of Sailing Crew
Oct 30, 2019
1,459
I use a half liter or so of bleach, then full the tank full, pump the galley pump until I smell beach, let it sit overnight and then flush a whole bunch of times. It takes a while and I don’t do it often, maybe every other year.Our town water has a low concentration of chlorine and my tanks are usually good. The missus sometimes complains about what she calls “fuzzies” floating in her glass but I tell her to strain them out through her teeth and stop complaining.
Nico WalshNicholas H. Walsh P.A.Admiralty and Maritime Law; Probate Litigation; Commercial LawPhone: (207) 772-2191Fax:     (207 774-3940P.O. Box 7206120 Exchange St.Portland ME 04112This message is from a law firm, and may contain information that is privileged and confidential. If you suspect you are not the intended recipient, please delete the email and call us.
Mar 21, 2015
28
Thanks Nico. Bleach sounds like a nice easy solution. Not too sure about the water quality in Portugal (the wine is of a higher standard and nearly as cheap).
Sep 24, 2008
346
Add bleach to water and fill the tank. Run the taps to be sure the bleach mixture sits in the lines. Let sit for 24 hours. Drain and fill/drain until the bleach smell is gone. Often the lines are worse than the tank but get ignored.
Apr 2, 2013
283
Well there you go, fill that tank with wine and pull the anchor. What could go wrong?…lol. LarrySent from Windows MailFrom: n4lbl alan.schulman@... [AlbinVega]Sent: ‎Monday‎, ‎May‎ ‎18‎, ‎2015 ‎9‎:‎02‎ ‎AMTo: n4lbl alan.schulman@... [AlbinVega]
Oct 19, 2019
921
Albin Vega 27 Limerick
But don't forget to flush out in Spring or your first coffee will pack a punch..On 19/05/15 00:17, groundhog
groundhogyh@... [AlbinVega] wrote:
Jan 28, 2001
694
Lyric has two bow tanks. One of which was leaking. We stuffed it with full of box wine bladders when we went to Mexico. We loved Mexico but not their wine!    Walt To: AlbinVega@yahoogroups.comFrom: AlbinVega@yahoogroups.comDate: Mon, 18 May 2015 19:05:50 +0000Subject: Re: [AlbinVega] Flushing through the Freshwater Tank
