C
Carl Gamble
The "Fresh Water Maintenance" article, in the reference library, states that the water heater needs to be off, when performing these steps. Does this just mean that the bleach/water mixture should not be run through the water heater or just that the flush mixture should not be heated.While draining out my fresh water tank, I also drained the water heater. The water heater was the source of the bad smelling water. If the bleach/water flush mixture is not to be run through the water heater, then what procedures should be followed to clean this out?
