Does anyone with a 356 know who makes those little round flush mounted lights with the switch that are in the Vee berth area.I have a bad one and want to get a replacement.Thanks
You could contact Hunter for the light, but first give the switch a good workout and make sure the connections are tight. We had a bit of corrosion in one of ours that we were able to "work" off the contacts on the switch.Good luck!
