I had that problem in the spring. I eventually put a new lower unit in and re-used the same bowl. However, at first I thought the thru-hull might be plugged, then I realized the head sink was draining through the same thru-hull fitting. So I pumped it figorously and it did break free whatever was clogging the system. Some dark particles came through for a while. Then it worked. But it developed a leak and was pretty old, so I replaced it with Peggie's expert advice. I also bought her book from SBO.
Peggie will probably be along soon to advise you. I'm not advising simply pumping it figorously as I did. When I did that, I had already decided to replace.
