LEAKING WINDOWS
Hi BOBI repaired a set of windows on an ABBOTT 22about 3 to 5 years ago. The windows are mounted on the outside of cabin (I think this is called flush mount) leaveng an 1/8" to 5/32" lip of the window where the water would run along top of the window and leak inside.All we did was clean real good removing what was there before the using a small amount rubbing alchol to clean the rest of the grim.Then used GE silicon clear and also the most expensive, put on light and ran finger down so it would be concave to let the water run off and makes it hard to see. It's been there ever since boat store out side all winter in northen ontario and sailed every day by it's owner 10 to 16 hours a day and not a leak yet.Spend a long time cleaning and let dry a bit extra and it works.happy sailing from the far north on Lake Timiskaming
