Flower pot, propane stove, and cabin heating
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
In a small boat this works; radiates well, and increases BTU's if necessary by turning up the flame. Small computer fan improves circulation even more and at .07 amps. With the outside temp in the 40's I could easily heat my cabin above 70 degrees. Chief
May 24, 2004
7,228
CC 30 South Florida
I'm I missing something? I have had good experience with the pots heater. It takes two pots; a larger and a smaller. The smaller goes over the burner and the larger covers the smaller. The burner flame will heat the smaller pot which in turn will heat the air between the pots and create an airflow as the hot air rises. As the volume of hot air passes through the hole on top of the larger pot it accelerates projecting it beyond what the sole flame could accomplish. The pots help concentrate the heat to provide maximum air flow. It is a time tested idea and in my experience it works well.
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
camping
I have used one of those small propane
bottle hearers that works great and great heat uses
small propane bottles and leave hatch
open little
