Of the many variables on our H310, the one thing I can always rely on is that one of the crew will forget to open the cooling water thru hull and then start the engine. Tried all of the usual tricks like wrapping the key around the thru hull handle, warning notice above the starter, and other etceteras, but it still happens.
I have found a flow switch from Defender Marine which will alarm when the sea water flow drops below 1.5 USGPM .......... so far so good. Now, after looking through the "Yanmar Service Manual", I find that the sea water pump on a Yanmar 2GM20F will put through 1600 liters/hr. with an engine RPM of 3600 RPM. This delivery capacity, I imagine, is with a total discharge head of zero feet as no discharge head is mentioned. With frictional head, velocity head, potential head, and the head on my beer, the capacity is somewhat less. If the rawater pump behaves like a positive displacement pump at lower RPM's, it would seem that with an engine idle speed of 800 RPM, the flow should be somewhat less than 1.5 USGPM and will set off false alarms with the flow switch.
Casting the theoretical mumbo jumbo aside, has anyone installed an "Aqualarm Cooling Water Flow Detector " on a Yanmar 2GM 20F and were they assailed with false alarms at idle speed ?
Thanks for any ideas on this problem.
Best regards,
s/v Island Hunter
Best regards,
s/v Island Hunter
