Florida Marlow Hunter 37 help needed
May 10, 2004
254
Hunter MH 37 Manitowoc, WI
So I am going down the Seadek rabbit hole for my Marlow Hunter 37. I made the cockpit templates before I had the boat hauled for the winter in Wisconsin. Seadek is going to use the templates to make cleaned up dry fit templates which are used to verify fit.
With the boat up north and me living in Daytona, I won't be able to verify the dry fits until June when we had north for the summer. I'd like to verify the fits earlier so I can have the deck pieces to install in June.
So here is my question:
Are there any Marlow Hunter 37 owners in central Florida that would allow me to come down and verify my dry fits on their boat? It's pretty much a non-invasive process. You roll out the mylar templates and check to make sure hinges, hatch pulls, etc lineup.
if you could help me out that would be awesome.
Jan 6, 2025
3
Marlow Hunter 37 Vancouver, BC
Hi there!
We are looking at installing a cruising spinnaker on our Marlow Hunter 37 and looking for ideas how to mount the tack.
I saw in your review you installed a spinnaker - do you have any info on how you installed it you would be willing to share?
Many thanks!
cruising spinnaker
Hi @stormh37. Welcome to the forum.
Kappy is wise to suggest that you start your own thread. Ask the question.
I am wondering if you mean asymmetrical spinnaker when you say Cruising Spinnaker. If so, then refer to it with that name. Otherwise, you may need to define what you mean by Cruising Spinnaker.
Likes: stormh37
