Re: Buck420
Nick,
I ran (motorsailed) south in Hawk channel on my boat during the day in the Fall of '01 and '02. Then ran it at night in Nov, '03, Dec, '04, and Nov '06. (I didn't go in '05 because the Keys were so torn up by Wilma, and in '07 'cause I went to the Bahamas).
Anyway, leaving Lake Worth Inlet about 16:00 (after running South from Ft Pierce in the ICW), it would take me about 20hrs (over night) to get to Marathon. With a GOOD chartplotter, and decent weather, it's not really that tricky. (And you can watch 20+ Miami broadcast stations on your TV from Lauderdale to almost Key Largo to help pass the time while you're motorsailing
). You may also have the opportunity to dodge lots of (cruise & other)shipping comming out of Lauderdale and Miami :cry:.
RE, the lobster pots. Prior to Hurricaine Wilma (Oct 2005), they were a real problem in the Fall. Saw almost none in '06 as most of the lobster fisherman had lost their gear as a result of Wilma. How it is now, I'm not sure.
However, when the pots were THICK prior to Wilma, I found that even if I did run one down, the wing keel on our Hunters seems to deflect the line and they (as well as crab pots in the Ches Bay) would invariable pop up behind the boat. In all my runs down Hawk Channel, I have never wrapped a lobster pot line around my prop. Lucky maybe. But, of course, at night, you absolutely can't see them at all, so I'm sure I've run a few down and not known it. Anyway, that's been my experience, I hope your's is as fortunate. But, even if you DO wrap one, at least the water is warm. Take a really sharp, serrated knife, just in case. And, take some heavy duty wire cutters because some of them use line with a wire inside it :dance: !
Good luck, wish I could join you, but I'm stuck up here this Winter...
Already looking fwd to next Fall.
