Unsecured floorboards and canned foods are the two mostly deadly things in the cabin during a knockdown/capsize.Why do you want to anchor them? Are you planning to sail up-side-down?
That how my 323 came from the factory. boards screwed Into the grid....to drill into the structural fiberglass grid, which gives me pause.
Can you cite a source for that? I would think that not having quick access to thru hull valves, pump strainers, etc in an emergency would be more of a safety issue than a loose floorboard. If you had to unscrew floorboards to find the source of a leak you might need dive gear before you solve the problem.Jackdaw said:Unsecured floorboards and canned foods are the two mostly deadly things in the cabin during a knockdown/capsize.
Check the official Fastnet accident report and anecdotal stories. Most of the people injured when below during the capsizes were hit by boards or cans. See: Fastnet, Force 10 and Left For Dead.Can you cite a source for that? I would think that not having quick access to thru hull valves, pump strainers, etc in an emergency would be more of a safety issue than a loose floorboard. If you had to unscrew floorboards to find the source of a leak you might need dive gear before you solve the problem.
Good discussion here.
Interesting. Are the fasteners specifically designed as floor anchors, or are they simply screws?That how my 323 came from the factory. boards screwed Into the grid.
Simply screws. Start out using a #8 or so, and if the hole strips out, just move to a larger size. Each board is supported around it's perimeter by the grid. There are 'bump-outs' at several places, and that is where the screws go into the grid. You can get by with only a couple of screws per board, but use more is you put stores under the board. Most, if not all, offshore races dictate that ALL boards be secured in case of knockdown-even the boards under the bunks/seats should be able to be 'battened down'....Are the fasteners specifically designed as floor anchors, or are they simply screws?
