Flojet or Jabsco or Shurflo??
181
Hunter 42 Passage San Diego, CA
I will be replacing my existing fresh water pump with a variable speed drive pump and there seem to be three available, all with roughly the same performance. Does anyone have thoughts on whether Shurflo, Jabsco or Flojet is a better pump? They all appear and read similar enough that perhaps they are all by the same manufacturer and marketed by different companies. As always, thanks for the input! Sandy
Nov 6, 2006
10,048
I have no idea how they compare, but I have had a SureFlo Smart Sensor 4 for 5 years now and it has been fine.. I was worried about the "resting" current draw, but it turns out that it is very low. less than a quarter of an ampere .. The pump is very quiet and works fine. It takes a second or two for it to respond to big demands, but catches up quickly .. It is so quiet that you won't detect a slow leak by the noise of a cycling pump.
Sailm8
Feb 21, 2008
1,750
Hunter 29.5 Punta Gorda
FWIW I had a Jabsco fail the first day of a planned 3 week cruise and replaced it with the same. It worked for one day and failed. Sailed back home and returned it to WM who didn't want to exchange it since I didn't buy a warranty. After some argument, it was only 3 days old, they exchanged it. Second pump is still working after 2 years. I guess you take your chance.
Oct 19, 2011
181
No experience with flojet? I am leaning toward shurflo but curious about flojet which doesn't seem to be sold by any of the marine suppliers but rather Camping World for RVs. I worry about Jabsco.
Rick
Oct 5, 2004
1,097
Hunter 420 Passage San Diego
Just an alternative
A Vacuflush system. Your boat is plenty big enough for the components. Will work with your fresh water system. It basically comes in a module that besides the head itself and the vaccum tank, is plug and play.
Bottom line, YOU CAN FLUSH A LOAF OF BREAD down it. No mascerator!
I have had to replace a collapsed line in all the years I have had one.
Not a salesman, just a though for you.
