Just one further consideration about turtles
Mr. Bill,It may be, in fact, true that the boat would turtle, however consider an experiment with me for just a moment. Let's rememeber that there is an incased 1400 lbs of water ballast in the bottom of the boat. Now, I know that that ballast water is no heavier than the water that presumably has flooded the boat, but consider this experiment. Let's forget about the Mac being a boat and let's talk about water bottles. Imagine an Evian bottle that the water has been emptied out and the cap replaced. When that bottle is placed in a tub of water, you can give it a horizontal spin and it will readily do so. Now let's imagine that we fill that same bottle with 1/2 to 3/4 volume with water and replace it in the tub. It now floats lower in the water, but still floats. Give it a horizontal spin and it still does so, albeit somewhat more sluggishly.Now, let's imagine we take that bottle; drain it and somehow attach to the side (on the inside) of the bottle a "balloon that we have filled with 5-8 ounces of water. Now refill 1/2 to 3/4 water and replace in the tub of water. It floats the same as before, but when we try to spin it, it only will turn until the trapped and attached water in the balloon starts to reach the surface level of the water. While below waterline, the "balloon" water would be the same weight as the surrounding h2o, but at waterline, it is heavier than the air it is now trying to rise into. What, pray tell, would encourage it to do so?If we move this thought back to the boat, it might be argued that the mast would draw the top down. ............How much does that mast weigh again? Was it listed as 35 lbs or 3500 lbs?I would certainly not argue for huge stability if a boat were flooded, but to turtle it, there would necessarily have to be an equal or greater weight affixed to the top to raise the weight of ballast (lead or otherwise) above the existant waterline.Another quick experiment would be to take a cylindrical piece of styrofoam. Carve out a small section in one side of it and tape a balloon of water in the carved out depression. Place it in the tub of water with the balloon at the top. Turn it loose. What happens? If our readers will notice, most of the styrofoam floatation is at or above deck level on a Mac. What does our experiment tell us about the propesities of the boat?I'm not trying to be a Mac protagonist in this little look. I think Abby Normal made a very estute observation in his last response about marketing genius. I just am a protagonist for logic and unemotional thought about any subject. I like my Mac, but it is because of what it does for my purposes. Is it perfect? Obviously not! Is it better than a Catalina or Hunter or Beneteau? That's not the point. Each have there advantages and each should be evaluated on their merits, not our prejudices about them. Some people deride "trailer sailors", but such a catagorie fits me just now and provides me with good sailing in a variety of places that many of them cannot enjoy because of limitations they face in getting to them.Sorry, I've digressed. Is'nt it interesting what we get into now that winter has curtailed our actual sailing?
