This is the info Chuck gave me:
The following is quoted from a very recent e-mail from Chuck (who I know personally and respect as an honest guy):--------------------"Comparing one prop with the next is not easy, especiallywhen most comparisons are subjective and vary depending onthe breadth of experience. However, there are a couple ofindependent tests that have been done that help. One wasdone by Cruising World Magazine in 1995 and was published inJune of 1996. In that test were many of the popular brands,including Flex-O-Fold, but not Gori. The Flex-O-Fold testedwas an older model with significant improvements having beenmade since."The second was done by Technische Universitat Berlin for DieYacht Magazine and published in May of 1997. That did notinclude Flex-O-Fold as it was a test of 3-blade props andwe did not yet have a 3-blade prop available. Later thatyear, when the prop was ready, we had the Professor who didthe original test repeat it using our entry. Because thattest was in a tank under carefully controlled conditions, wefeel the comparisons are fair and have a letter from theProfessor complimenting us on our fine product."If you want, I can send you the results. Briefly,Flex-O-Fold did very well. In the Cruising World test, theymeasured forward pull, reverse pull, speed, speed with adrogue and drag. On the maximum pull test, maximum speed:Flex-O-Fold 2-blade 235 lbs 7.15 ktsMartec Folding 165 lbs 6.70 ktsMaxProp 2-blade Feathering 170 lbs 6.80 ktsAutoprop 3-blade Feathering 182 lbs 6.90 ktsMichigan 2-blade Fixed 191 lbs 7.00 kts"In the reverse pull, which is not a good test (what you wantto measure is acceleration), we faired less well. However,the new blade design has increased reverse thrust by about40%. The results in the same order:FOF 97Martec 79Max 145Auto 122Michigan 112"In the drag test, the drag at 6 knots was measured with a 15degree down shaft angle:FOF 2Martec 3Max 5Auto 18Michigan 29"In the Die Yacht test, we again did well. They studied3-blade props only and measured the efficiency (defined asthe percentage of horsepower converted into thrust) over arange of speed of the various brands. The results, maximum,and the drag at 8 knots with a 0 degree shaft angle (noteGori substituted for Martec):FOF 64% 2.7 lbsGori 53% 2.7 lbsMax 46% 3.0 lbsAuto 56%* 16.9 lbsProwell Fixed 62% 94.5 lbs"Note: the Autoprop efficiency shown is at 8 knots. Theefficiency improves as the speed increases, exceeding theFlex-O-Fold curve at about 12 kts"In reverse, the test was again inconclusive. The reverseefficiency curves for all competitors crossed theFlex-O-Fold curve at a speed of about 3 knots or higher.The Flex-O-Fold curve remained higher at lower speeds."As far as barnacles and the like are concerned, I am askedthat question often at boat shows. I suggest the questionerplace his or her finger in a place that, if fouled, couldcause a problem. Few, with good cause, take the challenge,as the prop would mangle the finger or a barnacle when itopens. At the mooring, the down shaft angle alone is enoughto close the blades, keeping the barnacles away from thegears."----------------Ron
