Flex - o Fold Prop on a Hunter 34
Rob Carvette
Has anyone put a Flex-o-Fold prop on a hunter 34? If so what size? Installing this prop adds 5" to the length of the shaft. Is this a problem?
E
Ed Schenck
Not sure.
When I decided on a Flex-O-Fold your question did not occur to me. I had plenty of room between the shaft end and rudder. But the idea that the force of rotation moves four or five inches away from the cutlass bearing is worth considering. After only one season I cannot see any shaft looseness. And I am very satisfied with performance. It's a two-blade on an H37C with the small(20hp) diesel.
K
Kevin l. Woody
additional length
Dear Rob, You should not see much of a problem of adding additional length. As long as the section of shaft aft of the strut to the start of the propeller hub does not exceed 1.5 times the diameter of the shaft. Sincerely, Kevin.
