Flattening the mainsail.
Jim G.
I regularly read that bending the mast back will flatten the main sail but I have trouble visualising this. Seems to me that bending the mast back would give more body to the sail, allowing it to fill out more. Can somebody enlighten me on this. Thanks.
Ross
Jun 15, 2004
14,693
It only works with a fractional
rig. A mast head rig won't let you bend the mast with the backstay
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
When the mast is bent backwards the middle of the mast is pushed forward. When this happens the sail attached to the middle of the mast is drawn forward with the mast. This removes the draft(camber) in the sail thereby flattening it.
Ross
Jun 15, 2004
14,693
There is fullness cut into the forward
edge or luff of the sail. When that is pulled tight against a straight mast the sail won't be flat. Bending the mast to the same curve as the cut of the sail will flaten the sail. Same thing Alan said just different words.
May 18, 2004
259
J-boat 42 conn. river
alan and ross are both correct.
to flatten a main on a frac rig by tightening the back stay it moves the middle of the mast forward thereby flattening it. on a masthead rig if you have an adj. back stay it only will change the head stay tension. to flatten a main on these there are two things that can be done. one is to have a cunningham on the main an increase the halyard tension which pulls the draft forward and thereby flattening it the other is to have what is called a flattening reef point put in the main. this reef point say on a 30' boat is usually about 1 ft to 18" above the clew on the main. this usually is set at the same point as the cunningham eye. to flatten you pull in both tight. At the same time you also tighten your outhaul. hope this helps. s/v Que Pasa?
Rich
Don't try mast tuning with masthead rig
I fault a lot of the sources I've seen on sail tuning for not going into the differences between rigs before advising people on how to tune them. Fractional rigs are typically designed for racing and are meant to be tuned. Masthead rigs are typically designed for cruising and are not suited for tuning by the stays. You have a fractional rig if your forestay is attached on the front of the mast somewhere below the mast truck, say 80% of the way up the mast (hence the "fractional" designation); or if you have a babystay down lower in addition to your forestay. Masts on fractional rigs often have a fore-and-aft curve to give them strength in anticipation of being tuned; many have spreaders swept aft with no backstay. I think the special cut of the luff Ross was referring to would be found on sails made for fractional rigs or dinghys, but not on cruising sails for masthead rigs. Masthead rigs have forestays that attach at the top of the mast at the same height as the backstay. The mast is usually a straight-up stick and the spreaders are not swept back. Don't try any major fore-and-aft tuning on this type of rig; just keep the shrouds and stays at proper tension and concentrate on other sail trim techniques with vang, sheets, traveler, cunningham, etc.
Rick
Masthead rig bend
Rich, Our IOR racer not only has a masthead rig, but also a baby stay and hydraulic backstay. We do set the baby stay and apply the pressure on the backstay to create a bend in the mast and flatten the main. Why don't I see baby stays on newer masthead rigs?
Rich
May have been an IOR thing?
Rick, certainly the important thing is the adjuster and not the position of the forestay--if you have a factory-installed adjuster they clearly intended you to be able to tune the mast (and maybe the babystay is there to hold the proper tension at the base?) I haven't seen babystays on any boats beyond the late '80's, but it's hard to say whether that's a matter of fashion (maybe they were used to enable tuning on simpler aluminum spars and manufacturers didn't like that approach?!?) or whether that configuration doesn't work with the new rules systems (remember, IOR--International Ocean Race--rule has been obsolete for at least a dozen years, though I can't remember the acronyms of the 2 current competing systems).
Oct 25, 2005
735
Catalina 30 Banderas Bay, Mexico
Masthead Rigs and bend
On masthead rigs there are several ways to induce mast bend. Double lowers, a babystay, pre-bend, aft-swept spreaders all all ways to bend the mast. If you do a Google search on "masthead rig mast bend" you will get several articles that explain about the need for mast bend on masthead rigs. It doesn't take much and the maximum bend on a simple (no running backs or check stays) masthead rig is nothing compared to a racing fractional rig, but the bend is there and it is needed. I get about 1 1/2" of bend out of the mast on my C30. Many keel stepped masts carry 2-3" of pre-bend and get another 2-3" of bend with full backstay. Since the masts in cruising rigs are not designed to bend very much, the amount of sail shape control is limited compared to a fractional rigged boat.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
To continue what Moody said
...this is one of the failings with frac rigs, no backstay and roller furling masts. They loose many sail controls that help to shape the main properly for various wind conditions. As a result the performance of the boat is heavily compromised compared to a similar sized boat that has the ability to make all the need sail adjustments.
