1971 model colombia with 1 inch shaft
Someone mentioned adding heat to the flang to help remove
Early flanges were cast and crack when heated. will sell cracked one real cheap.
where do I buy a stainless steel 1 inch insert flange with three bolt holes about 3 inches in diameter
also rubber hose.
some one said $40.00 wow,
I saw $140.00 Help
anyone have a used prop = my boat came with a replacement which turned the wrong way and I bought a replacement which appears to be too large
capt bob 435 678 3436
also rubber hose.
I saw $140.00 Help
