At least two of the bolts securing the genoa lead track (correct name?) to the deck are dripping water internally onto the nav station... and probably doing no good at all to the deck core at the same time!
The obvious fix is to remove and rebed the track, probably using butyl tape. But removing all of the the 24 bolts that secure the track looks to be a huge problem. The track spans across the partition at the head entrance. From within the boat, 15 bolts are readily visible/accessible from in front of this partition and 8 from inside the head compartment. That leaves one bolt that is totally hidden by the end of the head partition.
This seems to be a design issue. Is there a workaround solution to access this hidden bolt?
