I need to fix the leaks in 3 of my six portlights. Is it something that I can do simply at the dock? I also need to replace my VHF coax from the mast head. Can I just pull it from the top down? Help! thanks
Down the mast yes, but through the deck if your boat is anything like mine there is a junction in the coax inside the mast at the step and the rg8 is sealed in there with some really nice and flex able sealant. Not to mention 30+ years of bird poo that somehow makes it in there.Twist new coax wires to old wires,tape, and just pull her through! Chief
Hi Jwhy I am going to buy this kit for my C30. Is it necessary to silicone the u shaped vinyl gasket to the glass and then silicone the vinyl gasket into the aluminum frame? How did you install yours thanks?Catalina Direct sells a kit for resealing windows. It includes new rubber seals, more than enough caulk, and directions, for a reasonable price. I did all six of my fixed windows with complete resolution of bad leaks.
