JC
I have recently launched my used C-22. After a few hours I noticed a small leak (seepage) from the knot meter sensor which is located adjacent to the keel lock down bolt. If possible I would rather not pull the boat to make repairs. I have an automatic bilge to prevent excess water in the hull. I have tried using a product call "Propoxoy 20" which hardens in water to stop the leak. This has not helped. I'm guessing the water pressure is preventing me making a good seal. Or maybe the fiberglass is to smooth or dirty for the epoxoy to bond well. I now have made made the sensor a permanent addition to the boat by use of the epoxoy. Does anyone have any experience (or suggestions) for making repairs while the boat is in the water? Is there a product that might work better then the propoxoy? Could I use some device on the outside of the hull to temporarly stop the water pressure on the sensor (I was thinking a toilte plunger)?
