Fitting vented loop on macerator discharge
C
Chuck
I am adding a vented loop to the discharge hose from the macerator in my Catalina 36 (per Peggy's suggestion). While the discharge hose to the macerator is the standard 1 1/2 ", the hose from the macerator to the thru-hull is 1". I have not been able to locate a 1" vented loop, only 1 1/2 or 3/4. Is there a prefered way to connect the loop to the this hose? Also, should I run a hose from the top of the vent in the vented loop to my vent from the holding tank? It seems like I would want to capture any leakage from that vent. Thanks for your help. Chuck
Dick McKee
Chuck or Peggy, you goat help me on this one...
I follow this board and am always looking or something I'm doing wrong, and this post got my attention. Why would we want a vented loop on a mercerator discharge line when the line runs from the tank to the mercerator and then thru a thru the hull valve as I thought was required by the USCG. The only time my valve is open is when I'm running ther mercerator. As soon as I shut off the power to the pump I close the valve and log the discharge. Am I missing something here??
Peggie Hall/Head Mistress
Two ways to do it...
You could get by with just a high loop in the line. It won't stop a siphon, but it will prevent your tank from filling up with seawater if you leave the seacock open. Or--you can use 1.5" vented loop by using 1" x 1.5" reducing adapters in the line. Personally, I'd just go with the high loop in the line. To answer your questions about potential leakage from a vented loop--there shouldn't be any. There should be a one-way air valve in the nipple at the top of the loop that only lets air IN, not out. Only when the valve is missing or it's failed should a vented loop squirt anything. To answer Dick's question--what's the point of putting a vented loop after the macerator: it's a fail-safe device. No, you don't plan to leave the seacock open, but human beings are fallible, and erring on the side of caution makes it a LOT harder to get into trouble than relying on human fallibility.
C
Chuck
Thanks - Reason for concern
Thanks for the input - my concern was that if the valve is open, and the macerator off, can the water pass the macerator and fill the holding tank? Chuck
Dick McKee
Thanks Peggy...I forgot about the human element..g
Prepare for the mistake and it porbably won't happen!!
Yes, water most definitely CAN
seep through the macerator into the tank. There are no one-way valves in a macerator. And, before you ask--No, you should not use a one-way valve instead of a loop...it'll restrict the outward flow from the macerator when it's running. Besides, valves fail. The whole point of installing loops is a passive system that protects your boat from sinking in the event of human error or mechanical failure. With that in mind, be sure to double clamp all hose connections too.
