Hi all, I have managed to fit the new bow roller from Steve Birch. It was trickier than I thought! The old bolts that hold the deck to the hull needed to be removed because they do not line up with the holes in the new roller. The pushpit really should be removed as well but I managed to lift it up far enough to slide on the front bit. The old holes were filled with epoxy and after marking, new holes drilled - be careful to angle the holes inboard a wee bit to allow decent size washers to go underneath ( I planned to fit a backing plate but there was not enough room really). Its is a two man job and a real pain to undo and refit the new nuts and washers onto the bolts. I countersunk the new holes to leave some space for a ring of Sikaflex stuff - bloody sikaflex gets everywhere!
The whole thing is bedded on sikaflex and if it was not for the restricted space at the pointy end it would have been a fairly quick job.
It is a substantial piece of kit and looks like it will last a lifetime. I am just waiting for the nylon rollers to arrive from Steve and then it will be ready for action.
Where do people store the anchor? I would like to keep it off the deck if possible - any ideas?
pic here...
www.flickr.com/photos/58818786@N04/6803575728/
pic here...
