Ralph, indeed that's my thought as well.
The most two 105Ah wet cells are gong to accept is about 52A of charge current in bulk. It sounds like you have a voltage drop issue. If you can't keep the voltage up you'll lose the ability for the batteries to take the optimum current. It also sounds as if your Link monitor may not be working correctly.. The factory reg should be set to about 14.3V +/-..
We ideally need more info to accurately help with your situation.
1- What is the alternator you have now model/brand?
2- How many amps?
3-How does the alternator circuit get back to the batteries?
3A- Do you have an "ammeter" in your engine panel?
4- What gauge wire is used between alternator B+ and battery bank?
5- With the batteries full what it the battery terminal voltage when charging?
6- With the batteries full what is the voltage at the ALT B+ stud?
7- With the battery bank at about 80-85% state of charge what is the B+ voltage?
8- With the battery bank at about 80-85% state of charge what is the batt terminal voltage?
9- With batteries in BULK what is the B+ voltage
10- With batteries in BULK what is the battery terminal voltage?
11- How old are the batteries?
12- Have they ever been equalized?
13- Has the specific gravity been checked?
14- Has every terminal, including alternator case grounding, been cleaned and checked?
I see owners spend gobs of money on alternators and quite often not improve the situation much. Your internal regulator will do BULK and ABSORPTION but will not FLOAT. However, it's a sailboat and FLOAT should not even be a deciding factor as you should rarely be running the engine long enough to hit FLOAT. With two 105 Ah wet cells the most they are going to accept, when dead or in BULK, is about 50-52A of charge current but this will drop. (25% of 210 = 52.5A). If above 80% SOC the accepted current declines fairly rapidly and it can take 10+ hours or more to get back to 100% state of charge, provided you're not experiencing bad voltage drop....
