W
walt
I picked up an inexpensive fish finder with the "puck" style transducer and the manual shows either a transom mount or a hull mount where the puck in epoxied to the inside of the hull. The hull can not be a sandwich construction for the hull mount to work. Im thinking about mounting the transducer to the inside hull bottom at the back of the boat in the lazerette area. It wont tell me if Im about to hit something with the front of the boat but still useful. Ill try and get it near the center so its always in the water when the boat is heeled. I was going to mount the transducer on the transom in the back but it looks like there isnt much water line above the bottom edge of the transom (ie, the transducer would be in some shallow water). The best spot would possibly be near the center of the boat but that is also where the rudder is and having the rudder just under the transducer probably does not help. Mounting it away from the center in the back seems like it would result in the transducer comming out of the water in a steep heel. I beleive the fiberglass on the hull just under the lazerette is not of a sandwich construction and also, I dont think the water ballast tank goes that far back. So I think the hull mount transducer should work fine?Any practical experience? I also understand that the wax used for seating toilets can be used to seat the transducer against the hull (work the bubbles out).. So I may try this first before going the permanent epoxy route.
