Winterize
The process is really fairly easy, I1.)Top off fuel and add fuel saver. 2.)Change the oil and oil filter.3.)Change the fuel filter.4.)Make sure the through hull to the raw water intake for the engine is closed, remove the hose, dump a gallon on "pink stuff" in a bucket, get someone to start the engine while I hold the hose in the bucket and suck up "pink stuff" until the water exhaust is pink. (It takes about a gallon for my boat.) Then hook the hose back up to the through hull.5.) Its also a good time to check belts for wear.I'm sure others will have additional to do's, however, that the basics.Randy
