Light winds...
Dan,Your tack line can run under your anchor roller and led back to a bow cleat. Have about 3-4’ of tack line above the deck to the bottom of the chute. Run your sheet to a block near the stern, and back up to a wench. As you undouse, do it from a mid-point on the foredeck to keep the chute and dousing lines away from the mast and spreaders. With your main out (with a preventer on if possible), undouse slowly to allow the chute to fill, once it fills then you can undouse quickly as long as it stays filled. To douse, again do it from a mid-point on the foredeck.I bought mine from HOW last year, and am very pleased with it.Also, try this link for more info. Good luck,Steve
