C
Calvin Smith
Just went of the second short outing in my new 170. Just thought I would share with you my first impressions. First, the nitpicking criticisms. 1. The window on the jib is completely useless unless you sail standing up. 2. The lock for the mainsail sheet can only be engaged by the use of a foot if you are sitting back or are on the rail. 3. The forestay is VERY difficult to connect without the use of the trailor wench. 4. The boat is more sensitive than I thought it would be to weight distribution. Now - The things I like about the boat. 1. It is very easy to rig with the exception of the forstay. 2. The boat is very responsive and seems to be quite fast. 3. It is very attractive. 4. It is comfortable. 4. The lack of a transom is great for swimming. 5. The boat is very solid. I get the impression that this is a boat that will last for a long time.I am sure that as I become more familiar with it, the list of things I like will grow but the first two criticisms listed above should be addressed by design changes. We sailed a Flying Scot prior to getting this boat. The reason we switched was that we trailor each time we sail and the Scot just took too long to rig and derig. The Scot has much more the feeling of a BIG boat than the 170 but lacks the excitement of acceleration and quick responsiveness.
