scott wilson
After changing the lube oil filter and the two fuel oil filters, for the first time, and with everything running fine, I just need some affirmation on a couple of points. First, the lube oil capacity is stated at 6 liters. I was only able to pump out 4 quarts through the dip stick tube. Should I be able to get all the oil out of the engine, or did I give up too early with the hand pump (my arms were tired)?On the fuel filters, I did not fill the secondary spin on filter with fuel before I put the new one back on, but there is a priming squeeze bulb in the fuel line just upsteam from the primary filter. So I opened the vent screw in the top of the secondary filter housing and squeezed the priming bulb 20 times waiting for fuel to come out of the vent screw. When that didn't happen, I started the engine ( ran normally)and waitng for fuel to come out the vent screw. During a 3 minute observation with engine running, there were a few bubles and a few drops of fuel coming of the vent screw, but no hissing or squirting. I tightened the vent screw and the engine ran fine at the dock for another 10 minutes. So is everything fine? If I had any air still in the line, would I know this right away with rough running or non-running engine? Scott
