Does anyone have some advice on strut repair for this model? Its loose and causing some vibration. The shaft was bent when I purchased the boat last year which is probably the reason for the strut being loose. I had the shaft straightened which reduced the vibration considerably but I believe the strut is causing the rest of the problem now.
Thanks
Live Wire
Thanks
Live Wire
