First 345 Toe rail
Feb 5, 2018
2
benateau first 345 NY
Has anyone ever replaced the toe rail? I have about 15' of damaged rail...no, it cannot be bent back. I was able to purchase one from Beneteau but it is 27 ' long. Kind of strange. It is also straight? Will this bend easily when bolted on?
Thanks,
Mark
Likes: Simon Sexton
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
The rail should be capable taking on the curve. Just start at one end, and place one bolt/screw at a time.
Just slightly tighten each as you go. Then as therail is initially fastened go back and snug the bolts. The process works for jib track, no reason why it shouldn’t for toe rail. just have to be careful not to kink it.
Nov 1, 2017
635
Hunter 28.5 Galveston
Mph2400,
Good morning! Your post captured my attention as I, myself, have just finished replacing the toe rail on the starboard beam of a Tartan 30. The most difficult part for me was having to remove the teak railing in front of the toe rail before actually removing the screws and prying it off with a flathead screwdriver, and then going to a boatyard and removing the toe rail from another Tartan 30 that was painted black; thus, I had to sand it to get it bare, and then I put a coat of silver paint to match the port rail. I figured while I was at it, I'd remove the port rail as well and repaint it. Both rails look good as new, and I'm proud of that little project! All that's next is redoing all the teakwork and doing some fiberglass work on the deck. Toe rails are pretty difficult to find, especially if you need it a certain size. I did have a friend who owned a Catalina 27, and he ripped the toe rail off a Catalina 30 and just cut it to size. The flexibility depends on the make and quality of the rail; Hunter, for example, uses aluminum toe rails, or at least they used to, and they would bend quite easily, and were a bit of a pain to replace. The one I replaced on the Tartan was solid steel, and didn't flex at all.
Jan 4, 2010
1,037
Farr 30 San Francisco
Check out rig rite they have a lot of this kind of stuff.. They do have toe rails for some French boats
Mph240
Apr 25, 2016
1
Beneteau first 345 NJ
Thanks to all.....I have the toe rail...got it from Beneteau but it came straight and seems very rigid so I was wondering how difficult it would be to bend. Seems as if it will give nicely. Thanks!
M.
Oct 26, 2010
2,227
Hunter 40.5 Beaufort, SC
The toe rail I purchased to replace some damaged rail from Hurricane Matthew was straight as an arrow. The yard installed it but it took the "gentle curve" nicely. By the way I have some of the Mid 90s Hunter toe rail left if anybody is interested.
Feb 19, 2018
7
Beneteau 311 Fajardo, Puerto Rico
Saludos Mark, where did you get the toe rail for your Beneteau? Hurricane Maria did damage to my Beneteau 311 toe rail and need to get about 30 plus feet of it. Thanks for the information
