finishing the edge
Pat
Jun 7, 2004
1,250
Where do I find 3/8 inch or 1/2 inch tape to finish the edge of a piece of plywood...as finished by o'day? Two summers of 109-110 degree temperatures and a locked up boat has resulted in the edge finish coming off.
Pat
Jul 19, 2011
60
Chaser 29, Oday 23, Port Elgin, Ontario
A kitchen cabinet contractor will probably sell you a strip if not just give it to you. Other wise a big box store will probably make you buy the whole roll
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
What you're looking for is "veneer edge banding." It's often iron on, and regular home irons work. http://www.veneersupplies.com/categories/Veneer__Products/Edge__Banding/
I never knew such things existed until a general contractor friend and I made a birch plywood computer desk for me. He pulls out the birch veneer edge banding, and ironed it right on all the edges of the ply. Then, he had a special cutting tool that cut each side flush with the plywood. Cool!
Also found this how-to article for you: http://www.joewoodworker.com/veneering/edgebanding-guide.htm
Brian
