Bruce Mulford
I installed a new ST4000 Wheel Pilot in my Hunter 29.5 in June of 1999. While it works ok, it is not as precise as I would have expected. It will wander 15 /- degrees each side of the course it is set on. I have tweaked all of the dealer setup settings on a trial and error basis. Is there a particular setting, or a recommended set of settings for a boat the size of the 29.5? (If there is you could e-mail it to me at mulf@aol.com). Or, could it be the location of the compass? I had it on the hull floor dead center under the helm, with results like the above. Then I moved it forward to bottom of the stbd hanging locker, which puts it low but off center about 2 feet. Both locations had single digit deviations after orientation, althoug the new location is within 2 feet of the batteries. Any suggestions will be greatly appreciated. Thanks for participating on this wonderful web site.
