I would say this if there were a slight leak in the head gasket it
may well be she would be slow starting and could pump fuel into the
exhaust and only run on one cylinder, It is also possible at higher
or near or at Maximum Rpm the piston might be coming up fast enough
to generate nearly full compression and she may well be able to run
six knots. If the engine compression , fuel and air mixture is
right you should be able to open the compression release crank her
over about two or three times winding up the flywheel fairly fast
throw the compression release shut and she should fir an run the
first time the cylinder goes over top dead center. When starting
with the starter she should start the first time the starter pulls
her over top dead center. IF you had a broken ring pull the hose
off that goes from the valve cover to the air filter, She would
likely be blowing smoke rings out of that 3/4 inch diameter hole.
If you had taken the engine completely apart the timing might need
to be set by loosening and rotating the high pressure pump. Once set
it should be correct from then on. I would replace the head gasket
and maybe lap the valves with lapping compound. Your mechanic will
have no trouble doing that. If She had been running on one cylinder
she was likely blowing black smoke from that cylinder. Lapping
should take care of any minor damage done to the valve seats bu
carbon smoke. I really would think that if you replace the gasket
and start her up and she should run well. Even if the timing were
off a little it is likely she would just smoke some then you might
worry about timing her. I can't imagine you have been running her
with a broken tooth I would think the timing would be so far off she
would not run at all. I have never seen this, so if someone knows
about this please correct me.
Doug Pollard
Albin Vega Sea Legs 2225
KK4YGO
On 05/22/2014 05:41 PM,
semi.retired@... [AlbinVega] wrote:
