Follow up
Feb.16,2001Hi Jeff,Just to follow up once more, are you aware that there is extant a school of thought which now advocates against full gel coat peels and for individual blister repair only, followed by an epoxy barrier coat system being appplied? I tried to find the site that discusses this issue unsuccessfully so maybe one of the other readers can provide it. There may also be a useful discussion in a back issue of Pratical Sailor.With respect to my earlier comments, the fact that the blisters are only in the gelcoat on the outside of the hull is consistent with the cause being the fibreglass water tanks, whether they are gelcoated or not and whether they are blistered or not. According to the MIT report mentioned earlier (I'm relying on my memory here) the coating on the glass fibres which is intended to increase the bonding of the resin acts to wick water at a molecular level. Because the boat is sitting in salt water the fresh water is attracted to it ( something to do with the difference in electron valences between H2O and NaCl). The glass strands end just below the gelcoat which is a surface barrier and the water collects there just under the surface since not all of it can pass through the gelcoat. At least that is how I remember the report going. It has been several years since I read it but MIT may be able to provide you with a copy.Of course there could have been a whole lot more research since this was done and this could now be irrelevant. I am also not attempting to contradict your surveyer who is obviously the expert on the scene and best able to advise you. I do remember the report recommending an epoxy coat or similar barrier being applied to the inside of hulls to stop the process from starting. It is to be noted that this water migration from inside the hull was not the exclusive cause of blisters, but was regarded as a major contributing cause. Whether or not the water tanks are gelcoated would appear to be irrelevant to the process of microscopic water migration by fresh water to the salt water. My point is that you may wish to line the tanks and do the blister job as well if this is in fact a cause. I expect your surveyor is better informed on the issue then I am down here in Margaritaville.Are you planing on using an Interprotect barrier coat for the boat?My next major job is a blister repair for this boat and that is the route I'm taking (I've done other blister jobs and this system works well.) but I would be interested in hearing about alternative systems as well.Fair winds,Brian Pickton of BeneteauOwners.net,aboard The Legend, Rodney Bay, St. Lucia
