Fiberglass restoring
Toby
On the inside of my Hunter 22, on the bottom, and about 10 inches up, the fiberglass is off colored, alittle brown from sitting water. Im wondering what to do to make the fiberglass white again and have the nice polish shiny look to it. Im not good with technical terms so the more specific about what i should do "steps wise" would be greatly appreciated. Thanks!
Jun 3, 2004
232
Acid bath
Caution here. My H23 is in the lake all summer and when I haul her for the season I use toilet bowl cleaner to remove stains at the water line. Lysol has a thicker gel type that holds to vertical surfaces, works really well and smells pretty good in the process. I'm sure it would do the trick. You are going to want to make sure all of your cushions are out/away and safe so you don't bleach them in spots. You might try it on a spot. Full strength, no scrubbing necessary. Wear rubber gloves. Eye protection might be nice too. I use goggles and old clothes as I power wash the hull after the toilet bowl cleaner has eliminated all of the stains and it splashes a bit. Not good for the eyes or skin. I squeeze it out of the bottle onto the hull and spread it around a bit with a soft bristled brush. I've never used it inside but if I was going to I'd rinse very carefully, and more than once so as not to splash anything around much and maybe use a drill powered pump to pump it out of the hull. If you have mildew stains on your inner wall carpet give Resolve Spot Magic a try. All the stains I had inside just disappeared without any scrubbing. Scotch Guard Oxy carpet cleaner works really well too.
