aircraft quality plywood
clean up the wound and remove all sharp or cracked areas before you do anything else. saturate the area with acetone (might be able to use a syringe to shoot into the surrounding area,and let dry thoroughly). make a template out of styrofoam, that just fits the underneath side of the wound, with a generous overlap of 4 inches or so. replicate the styrofoam template with aircraft quality plywood. wrap the ply wood in wax paper. use a heavy mat in a 2 or 3 layers that criss cross orientation of the weave. soak the layers enough to wet the cloth, but not drip everywhere. the trick is to keep pressure on the wax wood until the epoxy sets. it may be possible to install an eyebolt in the top of the wax board, through the layers of cloth. then attach a bungee cord to it and support it from above, through the original hole. (like ice fishing) once the resin is set, remove the eyebolt, and the wax paper covered wood. sand the area, to clean up big drips. epoxy coat the wood now without the wax paper and apply to the previous layers you just applied. you can use the same eyebolt to hold it. now, just glass over the wood below, and begin to fill in from above in overlapping layers, rotating the orientation of the weave. you do not need to use screws to hold the structure in place, the bolts on the cleat will do that. all of this in my opinion, but i have done this to a daysailor i had when i drove the pintles completely through the transom....now it is the strogest part of the boat.
