When I bought the boat several years ago, the fwd hatch hinges were loose in the fiberglass hinge pads. As an inexperienced captain, I got a West System repair pack from WM and fixed at the problem. In addition, I went ahead and drilled the holes through into the cabin and put bolts/nuts on. Also, a couple years ago, I put an anchor light on top of the mast and re-wired the steaming light. I drilled a new hole for the wiring thru the cabin top and only used silicone to "bed" the wires. The original wires (beside the mast tabernackle) I cut off at the deck and squirted some lifecaulk into that hole.
We recently removed the hatch to paint the inside of it, and decided to repair the hinge pads correctly. I got a quart of resin, hardner, some coidal silica, and figured a couple hour or so job.
The admiral went to work with the dremel (I was too chicken), and we have discovered that we are the owners of rotted core and wet core. Overall, the area adjacent to the hatch up towards the tabernackle and down towards the port on the port side of the boat - we have removed about 1 square foot of the gelcoat - we sucked out the rotted core and some of the really soaked but not quite rotted core.
The question now becomes - how big of an area can be done with just epoxy and when is it necessary to replace that core with new end-cored balsa? My guess is that I need core. According to Don Casey's book - the core needs to be epoxyed - then put in - then the deck epoyed to that....
Any suggestions? One good thing - where we have opened it up - the other core at the edge of where we dug out the other stuff has dried where the air and the heat can get to it...
I guess I'm asking for a source for the end-grain balsa core material... And does it come 1/2" thick? I believe that is what is in there now.
Thanks,
Ric
Thanks,
Ric
