Fiberglass hull depression
1
Hunter 22 Indian Lake, OH
I have an older Hunter 22 that had been sitting on the trailer bunks since last fall. Over the winter, spring & summer, the interior filled with about 18 inches of water that we discovered yesterday when attempting to move the boat. Aside from water, algae & mold over everything inside, we found depressions in the hull where the boat rested on the bunk boards, especially where the boards were attached to their trailer supports. I guess the fiberglass was not designed to support all that additional weight. The hull did not return to its normal shape after emptying the water - maybe better but the depressions are still evident. No cracks are apparent, and maybe if there was one, the water would have drained out?
Has anyone experienced a similar situation? Will the fiberglass eventually return to its original shape? Or do I just put the boat in the water and wait to see if it sinks or the hull straightens?
Any input would be helpful - thanks.
Tim R.
May 27, 2004
3,626
That is called oil canning and the hull should return to it's normal shape after a few days in the water. Fairly common for boats that are on bunk trailers for extended periods of time.
Feb 12, 2007
259
Ericson 25 Oshkosh, WI
All will be fine, the "oil canning" will dissappear. Go sailing and dont use your boat as a bath tub again.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Our 19' sailboat sits on a trailer that has the bare minimum of hull rollers. When we got her, there were some hull depressions in front from the rollers. I've rearranged the trailer rollers and winch-post so that the roller now pushes on a different spot, and more of the weight is borne on keel rollers. The original depressions have pretty much disappeared.
Please buy a fitted boat cover for your Hunter and don't let her fill up again.:)
higgs
Aug 24, 2005
3,704
Nassau 34 Olcott, NY
Oil canning will not always return to normal. Time will tell.
Oct 20, 2008
142
Oday 222 USA
Hull depressions or oil canning are commonplace. Also confirm that your wooden bunks have not deteriorated- and replace as necessary.
