Fiberglass cleaners
Peter
Apr 26, 2016
271
Macgregor 26M ca
On my Albin Ballad restoration I've run into some incredibly tough stains in the fiberglass and as a result have a shelf full of cleaners of various potency. But the one recommended by a fellow Vega sailor is Mary Kate's On & Off.
Link for review: http://tinyurl.com/7cph5ux
A lot of cleaners seem to have various levels of oxalic acid in them. "Wood Bleach" is an inexpensive product that is mostly oxalic acid crystals and when mixed with hot water is a very powerful stain remover.
http://alsnetbiz.com/homeimprovement/oxalic_acid.html
On the fore deck there'd been a length of steel chain rusting away for over five years which had left rust stains right into the gel coat. A solution of wood bleach, soaked in paper towels held down with a brick and covering the rust, gradually removed most of the stain over a one week period (Ikept wetting it with the solution). I'm sure a further application would remove them completely.
I also use it to remove rust stains from Dacron sails. In my experiments cleaning sails I've discovered Dacron is an incredibly tough material, impervious to most harsh cleaners. Oxalic acid, muriatic acid, bleach, have all been tried with varying degrees of success. Each type stain seems to have it's own magic remover. Be sure to experiment on an old sail first, of course! I have an old jib that is a "test pilot" for my stain removal efforts. It has mold, mildew, rust, blood, and several other unidentifiable stains to work on.
As always, any of these products require care and personal protection when using. Most packaging has all the appropriate precautions needed, and common sense helps a lot, too!
Peter
#1331 'Sin Tacha'
www.sintacha.com
Oct 30, 2011
221
Thanks. Just off to buy some!
I was wondering about protocols for the site.... it looks like when I reply to anyone, a message goes to the whole world! This seems to generate a long list of "messages" - is this the correct procedure or should I send mail to individuals and also keep comments relevant to the title?
ps thankyou to all for your help so far- I am delighted to have found such a rich seam of information - although I am a little in awe of the major refits and high quality work you seem to be able to do! No doubt I will learn!
John
pps I will put some pics on the site - she is a right mess I am afraid!
Sep 13, 2002
203
It's just a bulletin board, some folks choose to receive emails immediately, others prefer a weekly digest. The only folk who receive your mails are those who have opted in .. so don't worry about it.
What you do when you reply to messages is up to you. Personally I prefer to only keep the last one or two in the message trail for the context, but fortunately there don't seem to be any 'netiquette' police here to make it an issue.
Alisdair
PS bear in mind that the contributers are fairly evenly split either side of the pond. So, "Just off to buy some" is OK in USA if you want some "MaryKate On & Off" .. but you'll be struggling to find it in the UK.
