Fiberglass battens for sailpack?
Apr 19, 2020
74
Catalina 310 Kenosha, WI
I built a sailpack for my 31' sailboat last year that has a boom length of 13 feet. I tried extending pvc pipe to make it work, but the joints ended up being the weak spot and long story short, it doesn't work well. I'm seeking an alternative for a full length batten (around 14') made of fiberglass and would appreciate any suggestions as to where to source that?
thanks!
Ted
Jan 26, 2005
1,272
When I had a Stack Pack made by Doyle Sailmakers they used 3/4" diameter fiberglass rods. Metal sleeve connectors were used to splice two 7 foot lengths to make one long 14 long section. Mcmaster Carr sells fiberglass rods up to 20 feet long if you want a continuous length with no splice.
1,071
Pearson P30 202 Ottawa/Gatineau
I have made a few sail packs for costumers
What I used for battens is 3/4” PVC conduit, to make them long enough I Jan a wooden dowel inside the conduit by over 6” either side, a single screw on each side makes it very secure, not too expensive either
Likes: CowboyWay
Oct 31, 2016
15
Catalina 25 Watertown, MA
West Marine has 5/8" and 1 5/16" wide batten fiber glass stock available online. Max length is 12 feet. Not cheap, but you can have it delivered to your local store free. Comes wound up in a loop and will fit into the back of a car or SUV.
dmax
Jul 29, 2018
1,231
Telstar 28 Buzzards Bay
You should be able to find some used battens that no one wants - I have some from old sails but they're in MA.
