Fender inflation
Jul 13, 2010
1,100
Precision 23 Perry Hall,Baltimore County
Anyone know correct air pressure for 6" X 18 " Taylor made ?
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
I don't know if there's a correct pressure, but we just pump 'em up with a bicycle pump until they're stiff enough that they don't squash when I step on them.
Mar 20, 2012
3,983
like Jim 5757 said, or about 19" around... if you want them fully tight. i like mine a bit softer as they dont seem to have an inclination to pop out like the the over inflated ones do...
May 24, 2004
7,202
CC 30 South Florida
It is a good question but probably even the manufacturer would consider the answer to be based in common sense and experience. I guess the "correct" pressure depends on a number of variables. It would depend on the weight of the boat, the type and shape of the solid surface being protected against, the prevalent conditions at the dock or raft-up, and even whether they are being used vertically or horizontally. You want the fender to be soft enough to cushion a blow between two solid objects but hard enough so that it does not collapse. A fender will easily give way at the beginning and as it compresses it will continue to stiffen until it stops the force against it. Since no two blows are alike and we are not going to be there constantly to adjust pressure we usually fill them up to where we estimate that it will hold the strongest blow that we reasonably anticipate. My rule of thumb is that on a brisk wind or swells the fender should not collapse more than half its diameter. After a while you develop a feel for what is right for you and can tell by squeezing the fender whether the pressure is adequate or not. My big issue with fenders is trying to keep them clean.
Dec 14, 2011
316
Navicula 430 Hunter Toronto
Taylor made have a warranty for life... A great product.. However if you do inflate them there is a good chance they will not fit into your fender holder... And also after you inflate them and decide to deflate them they will not resume the original size... This is where the great warranty comes into effect.... I leave mine as they come from the manufacture
