Don Alexander
Hi Kevin,Last year I bought a 3 bladed feathering prop - JF make and 450 mm (17.71") diameter for my 376 with Yanmar 3JH non turbo 37 BHP engine. Like all featherers the blades are flat, i.e. they have no wash out towards the tips. The supplier said he would set it to 15" pitch as the original fixed 2 blade prop was 17" x 15" pitch. He said this equated to 25° of blade angle. I fitted the prop but the engine could not reach the recommended engine RPM and the boat reached hull speed far too early. The engine was overloaded.Then I did some calculations and realised the supplier had calculated this blade angle based upon a point at 57.8% of diameter. My appreciation of props is that most of the work is done by the outer portions of the blades so I would have set the pitch angle at a much larger diameter using either the geometric mean (root mean square) diameter of 70.7 % which gives 21° and I am tempted to work at 80% or 18.6°.Could you please advise what the pro's do in these circumstances.Regards,Don Alexander
